Everything posted by Polly
Ok well we may differ slightly on how long a normal holiday is, or how common it is to have a second/holiday home, but lovely, lucky you/them. The treated water carries away limescale deposits because the Aragonite molecules, though they do not bond to surfaces, do bond to their Calcite 'cousins' and carry them out in solution, over time.
- 199 replies
- hard water
- water softener
Hello Herb. The company is in the process of rewriting some of the website. Although it does not claim to create soft water, we would like it to be clearer. The system doesn't really come with instructions. There's nothing to instruct, you just fit it and it works. It does come with installation instructions. It won't do any harm if water is left for longer than 21 days, because in that case, which is unusual anyway, the treated water running through the system afterwards carries out existing limescale deposits over time.
- 199 replies
- hard water
- water softener
Here you go, Jack: We condition, not soften. I don't choose the wording on the website. We do not soften water. I think that's relatively unambiguous.
- 199 replies
- hard water
- water softener
Ok, my apologies if my explanation hasn't been clear. Aragonite is created in the water's solution during its pass through the Halcyan unit. CaCO3 goes into the unit in Calcite form, and emerges in Aragonite form. The Aragonite stays suspended in solution in the water in one's system and washes through your system with the rest of the water.
- 199 replies
- hard water
- water softener
Right.
- 199 replies
- hard water
- water softener
No they're not. Aragonite is around 50% more soluble than Calcite. Nothing precipitates inside the unit itself; hence its 30 year lifespan and warranty.
- 199 replies
- hard water
- water softener
Aragonite is formed inside the device. It happens in the time that the water takes to pass through, using yes JSHarris, kinetic energy combined with the alloyed fins. The effects last for 21 days, (bit harder to maintain in a kettle), then revert to Calcite. Yes Jack, I will send you the tests. No, JSHarris, I will not get into a debate about the laws of the company's advertising. I provide part time product support, and that really is outside of my responsibility. I'm here to explain the product, not the company. I'm sure you'll appreciate that really is not the role of a provider of Product Support.
- 199 replies
- hard water
- water softener
I might go and watch some cats CPD
- 199 replies
- hard water
- water softener
There is. The offset fins inside the unit create enough turbulence and pressure to create the reaction. No external source of energy is used. We don't advertise. If you're referring to the website wording, then yes, like I say, it could do with a tweak. But really, I'm in Product Support. I really can only be questioned on the product. Outside of this is not my bag. The fact remains that it's still more proof that it does work, than you have presented to say that it doesn't.
- 199 replies
- hard water
- water softener
Yes Jack, I agree, the wording could be clearer. I am but one woman in Product Support. The company is also in the process of changing the website. Yes, when the system is working at optimum performance, every CaCO3 molecule should transform into its Aragonite polymorph, and thus none should bond. I really only suggest this because they're a few pages long and in a format best attached to an email. I didn't say they're commercially sensitive. As for the pH thing, give me the afternoon and I'll have a bit more of a look into it then.
- 199 replies
- hard water
- water softener
Well, JSHarris, it is proven actually. I've said a few times now on here that we do have independent industry tests and technical information/data. All anybody would need to do is contact us directly and we provide them. It has: 'been proved to work after several decades'. We have reams of client testimonials and online reviews attesting to the fact. You, on the other hand, have no evidence attesting otherwise. And to answer your question of why it hasn't made other forms of 'water softener' obsolete - first of all, forgive me for making the usual clarification that we are a water conditioner. And the fact is: because no market is ever going to be dominated by one product, no matter how marvellous. Personally, I think a certain brand of tea is horrendous; but other people still drink it. And then of course we have the market who, such as Peter, just prefer soft water.
- 199 replies
- hard water
- water softener
Yes, you're right Jack. But it won't change the mineral content of the water. Calcium Carbonate will be just as present as before, just in a different molecular form. The conductivity of the water has also been shown to change once treated with a Halcyan. pH does not change at detectable levels, and Halcyan water has been approved as potable by WRAS. Aragonite is present in Halcyan treated water as a colloid suspended in solution. The effect of this lasts for 21 days, when it reverts back to Calcite; but of course by this point the water will have washed out of one's system. This means that Halcyan also has no wider effects on your water's environment.
- 199 replies
- hard water
- water softener
Halcyan is in the process of commissioning a university test on 'before and after' results ourselves. We wholly support the venture if members here would like to pursue one themselves, but please remember that the whole point to the Halcyan system is that mineral content will be the same both before and after conditioning. The system simply stops the Calcium Carbonate content from bonding and forming limescale. And yes Richi I did remove you on Twitter. It is my personal page and unrelated to my role with Halcyan. If you insist on sharing my personal pages on here then I suppose that is the way the internet works. If you must. I just don't really see the relevance to the Halcyan system. If you wish to ask questions on the system, you are most welcome to do so on here.
- 199 replies
- hard water
- water softener
Thank you all for your queries. Any that are likely to bring about further detailed questions, I would suggest to get in touch with me directly on info@halcyanwater.com to avoid narrowing quite a broad discussion. The results of the system itself are tangible and the claims we make, as to no use of power, no use of chemicals etc, true. The Halcyan is uniquely environmentally friendly and I am reluctant for it to be drawn in with comparisons with other similar options on the market, which do not provide such specific benefits. Please keep coming with questions on the system! I have a scientific background and can assure you all of my dedication to facts in this market. Thanks, P
- 199 replies
- hard water
- water softener
JSHarris I fear that our debate between the two of us is becoming a distraction to the overall discussion. I will gladly answer your specific queries between ourselves; please email me at info@halcyanwater.com. I appreciate the issues you are raising in a difficult market.
- 199 replies
- hard water
- water softener
Thank you Jack but that is certainly commercially sensitive and not something the company will share on a public forum. I am here from Product Support to quell myths on the system and aid understanding amongst the relevant market.
- 199 replies
- hard water
- water softener
It can be both, Dreadnaught. Is Wikipedia not sometimes King of Psuedo Science itself?
- 199 replies
- hard water
- water softener
I do not claim that magnets release chemicals into the water. Nor do I claim that sacrificial anodes use power. I say that Halcyan is the only system which does neither of these. I do not suggest that other systems must do both simultaneously. Many similar options release zinc into treated water. Halcyan releases nothing. Hence it is extremely sustainable, reliable and long-lasting. Regardless of us being the only system to release no chemicals into water whilst using no power, the reliability and tangible results of the Halcyan system are positively evident, and the Halcyan is an extremely valid option on the market, and not a sensational or over-promising system.
- 199 replies
- hard water
- water softener
I'm sure your neighbour was delighted! I say that in jest. I certainly appreciate you endeavours to find evidence in what can be a sensationalist and misleading market. With a Halcyan, the above would indeed be the case. Mineral content is maintained. We do not wish to change it. Calcium Carbonate would be just as present as before; it would simply be in the molecular form of Aragonite rather than Calcite. This is the essential part. Aragonite cannot bond to anything - itself, or your surfaces, thus no more limescale. But a mineral test on water will show the same content before and after treatment.
- 199 replies
- hard water
- water softener
JSHarris thank you for your Catalyst Water Treatment link. I've visited it but it's not really relevant to a Halcyan since a catalyst only of course speeds up a reaction, rather than creates or causes it, so Halcyan doesn't claim to be a Catalytic system. Halcyan's alloy creates its chemical reaction, not speeds it up. Kind , but thank you, it won't be necessary. You will note, Halcyan do not claim to change one compound to another. Instead we change one compound; Calcium Carbonate, from one polymorph into another (Calcite to Aragonite). We would of course create two new compounds if we were changing it. We are not. I've put in your quote above in italics why our claim to be 'the only system in the UK that doesn't release chemicals into your water, whilst using no energy. This differentiates Halcyan from such systems as Aquabion or Kinetico' is in fact true, yes. Please keep asking questions, we do appear to be opening opportunities here for me to explain how the Halcyan works. I don't expect to convert all of you, but I'd love to quash some myths or false associations with other systems. Thank you, P
- 199 replies
- hard water
- water softener
Hello members, I thought it may be helpful for me to reply to some concerns on here directly from Halcyan. To clarify, yes; the Halcyan is certainly and proudly a water 'conditioner'. Halcyan does not attempt to remove beneficial minerals from your water, nor do we claim to do so. Halcyan's purpose is purely to prevent and remove existing limescale. Thus, Halcyan is suitable for a certain proportion of the water treatment market; dependent on what the customer is looking for. It is the only system in the UK that doesn't release chemicals into your water, whilst using no energy. This differentiates Halcyan from such systems as Aquabion or Kinetico. Richi, I will indeed forgive your scepticism! Our 'alloy core changes the crystalline structure of the minerals in water..." ' claim is valid. We use a patented alloy to very simply and reliably change water's Calcium Carbonate content from its limescale-creating Calcite form into another Calcium Carbonate polymorph; Aragonite. Aragonite is physically unable to bond to surfaces or itself. So, to answer JSHarris's 'Where do the unwanted compounds go?' - with Halcyan, they stay in your water and simply wash out in solution, no longer forming limescale. After 30 years warranty with no maintenance or power usage, the Halcyan soon pays its way. It has an average 2 year pay-back period and therefore 28 years of savings. No device will guarantee absolute results, because they all rely on various factors outside of their control; i.e the ever-changing water input. We provide a 12 month guarantee confirming that if the unit doesn't perform as described, clients will receive their money back. This is specifically to provide clients with the opportunity to experience the Halcyan's effects for themselves with confidence. We ensure our descriptions of effects are responsibly described whilst recognising they can vary for different consumers. Essentially, Halcyan will always deliver a significant reduction in limescale build-up when sized correctly. We have various independent tests and reviews attesting to our results. Please get in touch via PM and I'll gladly send you over what we have. I hope this clarifies what we do a little, and when we are a suitable solution. Polly, Halcyan Ltd Product Support
- 199 replies
- hard water
- water softener
