Pablo68
Everything posted by Pablo68
  1. Dillsue, Many thanks for your helpful response. Sorry for the delay in responding; I didn't receive any notification from the forum and assumed that nobody had responded.
  2. I have a question regarding the provision of commissioning information to my UK Power Networks following a successful G98 application. I have recently self-installed a 1.7kWp grid tied solar PV system, which consists of five 340Wp panels and a Sunny Boy SB1700 grid tied inverter, all installed in compliance with BS7671 and connected via a dedicated RCBO in the consumer unit, on the roof of my house. The design and fitting was done in compliance with the MCS solar Pv standard document and all components, including Renusol fixings, are MCS certified. An assessment of the structural loading on the roof rafters (which had previously been reinforced with additional 150mm x 47mm C16 joists bolted to them as part of a loft conversation) was undertaken prior to installation, however, Building Control have not been involved and their approval has not been sought. I am a chartered engineer with many years experience in power electronics and electrical engineering, so was confident with all aspects of the MCS standards document and installation process. As the system was self-installed, I do not have an MCS installation certificate. I submitted the completed G98 form to my DNO, along with a schematic wiring diagram, grid tied inverter certificate etc. via email and received an acknowledgment email inviting me to track my application via their Smart Connect Portal. When I logged into the portal I found that an account had been set up in my name, but there were no details of my application. A couple of weeks later a received three email at the same time from SmartConnect. The first gave a reference number and thanked me for my application. The second stated that my application had been approved and had a PDF attachment giving the installation details; this email also included a statement reminding me not to forget to provide the commissioning documents using an integrated link by the end of January. It also stated that my export MPAN would be provided after commissioning documents had been submitted. The third email stated that UK Power Networks had updated their records and confirmed that the application, approval and commissioning procedure specified in Engineers Recommendation G98 for this type of connection had been followed correctly. The following day I received an email containing my export MPAN. My question: Given that the third email stated that the application had been application, approval and commissioning procedure had been followed correctly, do I still need to attach commissioning details or was this a request which they automatically include in their email? If so, what exactly is it they want to see? I had originally intended for the installation to help reduce our electricity consumption, whilst also doing the right thing for the planet, but now that I have an export MPAN and Octopus are trialling a non MCS accredited installed feed-in tariff, I would welcome suggestions as to whether this is worth pursuing, especially if I decide to add an additional array in the future? Many thanks in advance.
  3. Thanks very much for your replies guys. Wakaflex looks ideal and I've decided to use it. Regrading corrosion, the Renusol information sheet only states that corrosion is an issue if the installation is with 10 miles of the coast.
  4. I am going to fit solar panels to the pitched roof of a 1930’s mid-terraced house using solar roof hooks and rails manufactured by Renusol. The roof is covered with clay/plain tiles and has a pitch of 38 degrees. The original 4” x 2” rafters have been reinforced during a previous loft conversion with 47mm x 150mm C16 against each rafter. I have looked at various methods of ensuring that the roof hook installation remains watertight whilst also minimising tile lift and the chances of insects finding their way in. I came to the conclusion that using lead flashing would be the best solution and am not daunted by the fact that I will have to cut some tiles to achieve this. This video from Renusol (https://www.youtube.com/watch?v=nttpFKd_eG0) talks about their ‘Interflashing’ product at 9:25; I am not able to source this product but thought that lead flashing cut to the same size would provide a workable solution. All of the roof hooks would be located underneath solar panels, thus reducing the chances of the flashing being picked up by the wind. My question is whether I could use code 3 flashing, which is probably easier to work with, or whether I would have to use code 4? The screenshots below show the Intershashing system. Many thanks in advance.
