The ceiling is not up yet. I've spoken with a company that has advised to do the following.
Fit a VCL to the underside of the rafters, board and skim, use sealed downlights and seal them to the ceiling with silicone, then use a paint on VCL to the whole ceiling before emulsion. I like the idea of the spotlight shrouds, where do you get these from?
Starting to get fed up with tradesmen, just had to go around re-fiting all the door straps into the concrete infill (ICF construction), the fitter used wood screws into the foam only, an almost 1/2 tonned bifold, being held in place by bits of spray foam.
Thanks for the help.
