I have discovered a wiring link in the Sunamp that when connected causes the Heat pump input to timeout at 45 mins & switch to immersion heater.
	Removing the link stops this happening. If you do need a n Immersion boost at any time it can be done in the Daikin Onecta Smartphone app
	The Sunamp is designed so it first recharges from the heat pump, and after 45 mins if not fully charged it will activate the immersion to finish the charging. You can however disable this function, as described on section 3.8, page 36, table 16.2. of the manual
	You will need to remove link 3 to disable the heater backup option.
	Here is the manual for my Sunamp: https://sunamp.com/en-gb/wp-content/uploads/sites/2/2022/03/D0056-1-Thermino-hp-DN-SG-Heat-Batteries-Installation-and-User-Manual.pdf
