Thanks for the fantastic response.
Okay, sounds like dodging SolarEdge is better. Thanks for that advice. I knew the optimisers were only compatible with their inverter but hadn’t thought forward enough to think about what I’d need to do if/when one failed.
Shading shouldn’t be a problem, except for the different orientation they face. Ie - all of the west facing ones will get sun without shading, both the east facing ones will get sun without shading. Obviously that will be in the evening/morning respectively with a period in the middle of the day they *should* both get sunlight.
Re: landscape at the front. I probably could change my order to accommodate that. But I would need to work out which panels would go with landscape GSE frames - which I was finding hard before. I also need them relatively quickly as the builder wants to make the roof watertight this week coming. Any idea which panels would work with which GSE frames? Would probably need to be minimum 350w panels to make it worth changing from the 3 x 370w I have ordered.
Then the inverter. My feeling is that two small ones are probably more hassle than one slightly bigger dual MPPT. Are optimisers still needed if all the panels of each string will get sun equally, and they’re on separate inputs into the inverter?
Any recommendations for such an inverter?
Thanks - assume you mean a single small inverter with input for 2 strings, rather than a single input? I think wiring up two separate inverters to the house might create a bit much hassle. Any suggestion on which inverter?
By the sounds of it I can get away without optimisers, if the panels are on separate strings to the inverter. thanks for the insight!
