Electrified
Everything posted by Electrified
  1. Thanks Mike, sounds like solid advice!
  2. I was wondering exactly the same regarding packing out when I stumbled across this thread… i’m also looking at running radial MVHR ducting within the wall. However I was planning on using Flat channel ducting which is about 50mm deep so should fit in the 70mm void with no issues. Then having a flat to round adapter in the loft above and under the floor below to switch back to round ducting. Maybe something to consider although I’m not too sure if it’s okay to use this type of ducting for radial 🙃
  3. I’m just embarking on a renovation of a Victorian terrace and have stumbled across this forum. looking to share ideas and learn from others.
