dave1967
Everything posted by dave1967
Hi Got 2 1200s. No idea why. Maybe because old array of 10 had a few panels lower down and partly shaded. I now have a row of 6 just below the ridge.
Evening Got the new panels 6 x dmarc 410w Now have another problem as they may not have enough voltage to kick start my 2 sunnyboy inverters. Didn't kick in between 3 and 4 on a dull day. Is a new inverter the answer?
I thought that 100 each was ok. Change of anyway 6 420 will fit the roof better so going with them.
Good question. I dont know if i can or not.
That was from ovo. But they advised to check with ofgem who said what they say is not legally binding however as long as all the plant is not decommissioned up to the grid it should be fine. So a swap for repairs or cosmetic should be ok. It also says this on their website.
Yes they are but i have read as long as they are the same kw it is not an issue.
Hi We are reroofing so our 2011 panels need to come off and as they are badly fitted and an eyesore we are going in roof. Can anyone help with a solar company who can supply. I can get 8 ja 325w panels for £850 but they cant supply the fittings and mountings . We dont want to pay more than £1500 if possible. Any help appreciated.
Thank I will be aiming for .18.
Ok thanks so vapour inside after pboard.
Hi It a large timber dormer 4 m in length with a 1.9m set of doors. It will be tiled and was planning to just use rw slabs between joists and rolls of insulation in the loft area up to required amount.
Afternoon all I will be finishing off the dormer, can any one give me an idea if my plan will pass bc. it needs to be done with sound a major problem as on a flight path at certain times. 2 layers of 12mm soundboard staggered, 100mm rw5 in the 120mm frame, 20mm air gap then, decent vapour barrier outside, then celotex to meet u value and breathable membrane , ecoscape composite cladding over the top. Thanks for any advice in advance.
ok thanks , cant find any online so probably wont be much use to anyone if I reroof
agree, not seem a marley the same .
cheers, does anyone recognise the hand logo on it? its around 1965.
Can anyone tell me if eurocones are reusable as i am relocating my manifold. Also does anyone know where a replacement valve can be bought for a wavin manifold? I cant find a supplier, cheers
Ok they came out. Said water in expansion tank is not always an issue with viessmamm 100. It was pressured up again with a pump. Prv was ok. Not sure what else he did but said it was not set up correctly for external control which he fixed. Not Sure how that was the main issue as it been fine for 10 months but seems ok now and no pressure loss. So all good.
Viessmann doing it next week under warranty after I explained the issue. Cheers all
Will do. Cheers
The grey drain hose drips but i believe it is shared with the condensate drain so im not sure.
Thanks but i don't get a pressure increase.
Maybe, just insure why im osing pressure when inam ot getting the telltail high pressure associated with u/s expansion tank.
