Good morning all. This is my first post so please point me in the right direction if I've posted in the wrong place, asked a question that's already been covered or broken the forum rules.
I bought my house around 5 years ago and I have slowly been renovating it ever since. About 3 years ago I had an Air Source Heat Pump installed, as we have no mains gas and at the time, the RHI was generous (it paid for the system).
Last winter I picked up an absolute bargain of 4kw solar panels with an inverter for £400. I installed it myself and I am mostly happy with it. Since then I have changed the inverter so I can connect via bluetooth. Recently i have had a smart meter fitted..........
Now that I have the smart meter fitted I can see exactly what the power I'm sending back down into the grid. Actually, I knew this before, but its different when you can see the display 'laughing' at me!!! After the install, I did contact an MSC company and ask them if they would inspect and certificate. They told me, that it was virtually impossible for them to do this as they had to provide proof of where the panels came from. In any case, they said I'd only get about £60 a year back from the one or two electrical suppliers that offer a feed in tarrif (5.5p per KW).
So......I was thinking, there must be a smarter way of using my solar and ASHP. I have my heat pump set for 21degrees in the morning and evening and all other times it's set to 18 degrees. There is an 3kw immersion in the tank, but it's only used to prevent legionnaires disease. When the heat pump is on it draws around 1.5 kw. At the moment, the heat pump thermostat/programmer is not wireless and I am not able to connect to it via bluetooth.
I was thinking that maybe if the sun was shining during the day and producing over 2kw I could somehow activate the heating to go up to 24 degrees. This would warm the house during the day and therefore require less heating after the sun sets. Obviously, I would need some kind of app or software to run this. My ASHP is a Mitsubishi Ecodan and my inverter is an SMA.
Thanks in advance for your replies, Nathan.
