Bryera
Everything posted by Bryera
I ended up removing the wall and putting up all new and plastering it but this time I got vents in the wall to stop condensation and so far all good 😁👍🏻
So do I need a different transformer and if so witch one ? And yer I had ring door bell for long time and sick of changing batteries as I have my settings to max and it covers a big bit of the garage so battery seems to go down quicker getting up on power I have one less job to do one less thing for wife to shout at me about 😂😂
It's the old slats and plaster its just so week all would have to come off to plaster over that and then it would be new frame plaster boards and plaster that seems more money ?
Sorry that meant to say rubbish plaster my phones changed it 🤦🏻😂 so a thin bit of ply over the top of the RUBBISH SHOT plaster and wallpapering over that keeping the old plaster work tucked away saving me geting it out Framing and plastering just want to cover it but want to know if there would be any complications doing so ?
Ok so I have the top of my house to do and all we are doing is wallpapering the walls are very old and had to replace one already but what I want to know is could I us a very think ply to go over the rubber plastic and wall paper on to that
Yer that's not a option mate doing my decking and it's not coming up going to get water out and concrete it in the hole and then a fibreglass paint to waterproof it 👍🏻
Hay guys got this pipe that needs repairing would replace it in a Ideal world but just started laying new decking and not digging and stuff so wanted to know if I got the water out is there away I could repair this hole In the drain ?
It's to long for a steel all way going to rsj under it and build frame and connect them steel plates think that should be enough plus I can do that then 👍🏻 got any pics of the steel plates your on about ?? Thanks guys 👍🏻👍🏻
Thanks guys So I am getting a RSJ and going to be supporting it from that then I will be looking at taking the wall down what are people thought on this ? I feel that is the only way I can do it as that wall is definitely coming down 👍🏻👍🏻
Hay guys and girls looking at taking down this wall in the garage it's an unused toilet so wanted to us the space for more garage room but moving a brick out I see the support is sitting on that wall for weight, is there anything I can do ?
Hay guys I have a new patio I'm going to look at lane I just wanted to know if there was any site I could put the size of the area 14m2 and what type and get the design so when it comes to laying it I can put it down with easy something like this but with my area ??? Thanks ☺️
Is it double linseed oil I need or just linseed oil to mix with the red mastic sand I am looking at geting ?
It is Accrington brick mate mastic better ??
As title really I have used both before just want to know what you guys would recommend for pointing brick work up ? 😊👍🏻
I am not planning on putting it on top I plan on cuting bit out of the sleeper to keep it low and to give it more strength like this
What size of wood would people recommend to take downward weight 6x2 or 4x2 4x4 ???
Hello I am puting in a swing for my little girl up and for us to have like a bed swing for the summer I wanted 4 sleepers in ground and was going to cut in to the sleeper to build my top frame that will be holding my swings. What would be the best wood to us and what would be the best way to build it for strength ?? Was thinking 4x4 all would will be treated ??
Hay guys looking at changing my front door to something more modern and composite is coming up a lot and am looking about £1200 to £1500 I been tolled but my worries with this is they will take everything out and fit to the stone work I have and am worried there's a good chance it could get damaged or could damaged all the windows around it. One company don't even know if it was possible to be done? On something like this would the recommendation be getting a wooden modern door or best still to keep looking for composite and PVC frame? It's more how they will secure it and any damage with putting it in I am worried about can anyone shed some light on this ?
Hay guys looking for some bright up down lights for out side my house. Most of the ones I have seen are very dull what is it I am looking for for decent bright PRI up down lights ? Currently have this setup which is on a switch and presuming that with the PRI sensor on the lights to work I just need to leave the switch on all the time ? and should just be a simple swap from what I have already ?
Now thinking get some concrete to go over the top ones all hardcore is all compacted then stones then I have my strong base for van to go on to drive and stones will just make it look nice ???
7.5mx4.6 = 35m sq Is what I am working with
Hay guys you help me in the past on here so thought I'd give it another go. I am currently extending my driveway to make it fit two cars on it and got all the hardcore ready for compacting (wracking). For the finished product I have £1000 and know it's not a lot for a drive way but wanted to know what sort of stuff I could do as at the moment the only idea I have that I know I can afford is stone the area. Just wanted to know what overs would do with that £1000 for a driveway ??
Thanks all of you for the advice ? yer the insulation I have down has the silver on both side so not so worried about moisture hopefully ? have been looking at this stuff to lay on top ? Or is that to much ? Any more suggestions or where I can get stuff from much appreciated ? So with having no felt under lay under my slate that foam stuff would be no good so thinking doing something like I did in my van conversion ? silver foil then some 50m kingspan would keep a lot of heat in the house and rooms I hope ??
Hay guys and girls not been on here for a long time and I have moved since and remember how helpful people was on here ? I have just got up all the very old insulation from the loft and binned all the old stuff and started laying that kingspan stuff between the joists where I have put a new bedroom ceiling in. Now I want some of the fleecy stuff to lay on top of the kingspan for more insulation what's best to go for ??? I will also at some point be doing in between the joists where the roof is and was thinking more kingspan but keep seeing the foam stuff they spray but see a lot of mixed reviews on it just wanted to know what's best ??? Thanks again guys and girls this is something new to me so learning along the way so any help or advice you have is much appreciated
