IanMcP
Personal Information
  • About Me
    plot in Suffolk. New to all this but getting stuck in...
  • Location
    suffolk
IanMcP's Achievements
Regular Member
Regular Member (4/5)
5
  1. Having a few tweaking issues and I think an infrared / thermal camera will help find cold spots in the floor (wet UFH in insulated slab) , possibly caused by differing flow rates and set up. does anybody have one I could borrow or suggestions on where to get hold of a cost effective solution ?
  2. Had to give them away.
  3. As said. Run cable to ceilings for access points. Use Ubiquiti networking. This kit is awesome and will allow ‘roaming’ on WiFi as you go around the house. can’t have too many cat6 points.
  4. See other post for details. They need to go now don’t understand why you wouldn’t add these to your project as a starter pack ? 🤷🏻‍♂️ anyway. I need them to go now. Come and collect !
  5. No takers ? 🤷🏻‍♂️
  6. All valid @Russell griffiths hence me throwing it out there. 👍 like to idea of render then simply clad over that. I have part grey render so would do that to match windows then timber over. horizontal battens would be as many needed. Say 600 spread ?
  7. Membrane purely cosmetic to cover the blue in the gap. But if it isn’t breathable the battens behind won’t get to dry out ?
  8. house build is Nudura. I have 4 areas between windows that I want to clad. Remaining external is render. The effect I want is vertical slatted. Think 2x1 with a 10mm gap I I I I I I … like this 🙂 my question is how best , simply to construct this. for simplicity I’m thinking : - 3 horizontal , top middle bottom , battens. - black breather membrane across area. Black to hide the lovely blue wall. - vertical slats , C24 painted. With 5/10mm space , which would then be black. Any issues here ? pointers on best membrane welcome ! ta. oh and nobody has bought my spare blocks yet !?! 🤷🏻‍♂️
  9. I would say Luton van should suffice.
  10. Drop me a pm can email pics over
  11. XR35 blocks - x20 XR35 90 deg corner - x10 standard blocks - x3 Standard 90 corners - x38 Full Pack of Cill / Header Clips box - x3 Formlock bundle of 10 - x10
  12. £2k to take it all away. Blocks and accessories. Bargain for your new build.
  13. I have £5k++ of Nudura block and extras left over from my build. collection Bury St Edmunds a mix of standard blocks and XR35 straights and corners. plus metal frame , clips all stored under cover get yourself a bargain starter pack for your build ! You can mix the standard and XR35. I have on my build.
