Trex01
Trex01's Achievements
New Member
New Member (2/5)
0
  1. and do you feel the 350 is resonable or steep
  2. I think its always good to get a back up ie. gas boiler /elec shower, water only boiler / ASHP heating
  3. Why do you say that?
  4. If you house is well insulated and the system is well designed (its important), then you will save a significant amount of money. Just look at whats happening to energy prices right now. They are not going down
  5. 240, thats substantially more than a boiler, for a service that looks like it just cleans and checks stuff
  6. Thanks. I was aware of the G£ requirement
  7. Does anybody know of a national emergency response company that covers heat pumps i.e., like British Gas or Homeserve?
  8. How important is the annual maintenance service and what’s involved in it? Right now, it looks no different than the annual boiler service. This is what I have · Clean evaporator coil; · Check antifreeze; · Clean magnetic filters/strainers; · Remove trapped air; · Check primary pressure; · Check flow rate; · Check controller settings; · Ensure heat pump system is safe; · Clear debris from drip tray and ensure water is draining away correctly;
