Floor cleaning and maintenance
jaluky
How to clean Hi Gloss tiles which seem to be very popular, these tiles seem to dry with smears often looking worse than before you started. The problem is the cleaning fluid you are using which, if not removed properly, will cause a build up or layer, remember... the tile was shiny when you laid it.
Often just using clean water is the answer and then a good dry buff...give it a go and let us know.
