Managing uneven walls
Hi All,
1950s cottage undergoing a reno (as most of you already know). Having picked up my shiny new 1.8m spirit level and walked about the house checking walls, most of them are uneven (rolling hills & valleys up to about 20mm variance over 2m) and out of plumb. Could be the cheap level is too straight of course.
My initial plan was to rip off the 40yo lining paper and roller-skim all walls with something like Dallapro, but I was expecting a much better starting point to be honest.
What would be your advice for managing a Dr Caligari house? I'll eliminate all sharp transitions hidden behind the paper (like a bricked up old internal door that was poorly plastered over), but I think I'll have to leave the uneven walls as they are and just skim over them? I've got stunning views over the hills of Perthshire out of my windows, so the internal hills & valleys on the wall should be a good visual match. Just need a couple new roof leaks to start running down the walls to imitate the rushing burns.
Not getting a plasterer in. When I was young, I was dumb enough to listen to my parents, study well, stay out of trouble, get a degree and a professional qualification and a respectable job, so there's no chance I can afford a plasterer to spread some mud on all walls in a medium-sized house in the current economic environment.
I might wait for the next recession of course - I think we're finally about to crash.
Thank you.
Edited by tetris
Live with it and embrace the character?!
Is it loose or are the walls sound?
Walls are sound. A few small blown areas where there were old mounting points for TVs, sinks, old wiring chasing, etc - all minor and will be knocked off and filled.
The rest of the cottage is full of character, inside & out, so I won't be losing sleep over it. If I was I'd get a plasterer. 😂
Are there any rules of thumb of what variance over 1m or 2m is acceptable? I can foresee some issues with gaps between the wall and wardrobes unless I go fitted.
Also, paint options to avoid?
I've read that central source of light helps mitigate the unevenness look.
Surely, mine can't be the only house with out of plumb walls - anything built before 19XXs must be the same?
