Daikin Altherma 3 - default / optimum settings
I'm after some help with my Daikin Altherma 3 heat pump. I would ask the installer, but their communication skills / support is shockingly poor! It's only been in a year and works just fine, however I would like to optimise and check the settings are correct?
I have third-party external thermostats and a UFH throughout the house. The leaving temperature is currently set at 28°C, does anyone know if that is right? It looks like I'd be better putting it into a weather dependant setting, but I don't understand what that does?
A pointer towards a decent video / explanation would be useful. Most of them seem to assume a higher level of knowledge than I can be arsed to attain!
Many thanks,
Gary
Hi there, this depends on lots of stuff, but most importantly dies your house get up to temperature you want, if it does it most likely correct. House heat loss, screed thickness and pipe spacing all make a big difference.
At that flow temp WC gains you nothing. Would assess if the heat pump cycles at all, if it does you could increase flow temperature to get long stable runs and overall a better CoP.
Best way to set up is with data, compare what it does and how much electricity it uses.
I settled on fixed 33 degs, as the ASHP doesn't cycle, it runs steady for long periods, and actually gave a better CoP than WC.
I would try to get the system down to single open zone and remove all the UFH manifold actuators. Leave the thermostats and use them to tune the system so any one can make the ASHP run, but when it runs all zones get heat. I am using two thermostats currently to do different things at different times (make best use of Cosy without under/over heating the house)
Edited by JohnMo
Weather compensation(WC) varies the temperature of the water leaving the heat pump depending on the outside temperature.
Your house has a pretty fixed level of insulation and unless you change things the only variation is opening and closing doors/windows. If youve got a particularly draughty house then the wind blowing can take out a fair bit of heat to! Draughts aside, what makes the house loose heat quicker or slower is the difference in temperature between inside and outside. If you have a fixed indoor temp then it's variations in outdoor temp that change the heat loss.
With WC as it gets cooler outside the HP automatically increases the leaving water temp to compensate for the higher heat loss. As it gets warmer outside the reverse happens and the leaving water temp gets lowered to compensate for the reduced heat loss.
In setting up the WC you, or some clever software, needs to tell the HP what temperature the leaving water should be when it's warm outside and when its cold outside. As an example and that's all it is, our HP is set to 25 degree water temp when it's 15 degrees outside and 34 degree water temp when it's-2 degrees outside.
@JohnMo has replied while I've been writing this so hopefully you'll start to understand WC and his suggestions on setting things up
Thanks for the information, very useful. It's a compact, highly efficient house with zoned UFH. I'm logging the data, so in time will look into optimising.
