End panels, one or two?
Kitchen design altered a touch so the plan is a bit useless, winging it a bit and I’m left with a question…
We have at the end of run, a freestanding dw, which the worktop will be sailing over. Ordinarily a cupboard sized end panel would suffice to finish after the dw. Next to the dw, we will have a side by side American ff, which I’ll build a housing for, comprising of tall gable panels, top box etc. This leaves me with a question, should the tall gable panel will go against the shorter end panel for the dw, or should the tall gable panel replace the short end panel, which I would then brace suitably to create the opening for the dw and accept the worktop.
I'd let the tall gable do both jobs and leave the short end panel out. Its the neater finish, you dont get two panels side by side showing a double thickness line down the front, and you gain back 18mm which can be handy when you're squeezing a dishwasher and an American fridge into a fixed length.
The worktop just lands on a batten or a couple of worktop brackets screwed to the inside face of the gable at the right height. Main thing is the gable has to be solid, as its now carrying the end of the worktop and getting knocked by the dishwasher door and the fridge. Fix it to the wall with brackets at the back, to the floor and to the top box and it wont go anywhere. Set the dishwasher gap to what the machine asks for, 600 for a full size one, and keep it the same at the top and bottom.
Doubling up only really makes sense if the tall housing is a different depth or finish so the short panel would look odd, or you want to be able to pull the fridge housing out later without disturbing the worktop.
One thing to check before you fix it. side by side fridges usually want a gap at the sides and top for air so look in the manual for the figures, and see how far the doors need to swing to get the drawers out, a gable tight on the hinge side can stop that. Also seal any cut edges on the gable near the dishwasher as the steam gets into them
