New build VAT exemption
Hi all, planning on a replacement dwelling where we are demolishing the existing property but retaining the foundations and beam and block base.
As I understand retaining the foundations and ground floor slab is permitted however as we are on a slope we have a beam and block base and at one end there is a 450mm dwarf wall below the beam and block base.
Will retaining the dwarf wall be permitted for the VAT exemption?
I figure although it’s suspended it’s still the ground floor slab as such but wondered if anyone has any advice on this ?
Didn't even know you could retain gf foundations and slab. Like your post says it is gf so I'd be taking that as the rule
