15 hours ago15 hr So thinking of putting some electric u/floor heat in the downstairs loo which will have procelain tiles.Do people recommend I remove the old floor boards and install some other board onto the joists ?I need to stick to about 40mm total makeup including a 10mm tile.(Thinking of using thermosphere - can you integrate it into heatmiser ?) Edited 15 hours ago15 hr by Spinny
6 hours ago6 hr I would keep the boards if they are solid and level, and put a tile backer board over them rather than taking them up. That saves height and gives the tiles a stable base to work from. With 40mm total and a 10mm tile, you have about 30mm left for the backer, mat and adhesive, so a thin backer board makes more sense than a thick one. Screw it down well, stagger the joints, and check the floor does not bounce before you tile. For the Heatmiser question, I would check it with the mat maker, as some mats need their own sensor and controller setup.
2 minutes ago2 min Author Thanks, stevenlee - wow you are far away - do you live in CA ?However I didn't make it clear - the 40mm is from top of joist - so it would include 21mm floorboards leaving around 19mm...Top of JoistFloorboard 21mm backer board ?Flexible Tile adhesive to stick down matt 2.5mmMatt with electric cable 5.5mmFlexible Tile adhesive 3mmPorcelain Tile 10mmTotal 42mm + backerboard... so too highI don't have any insulation between the joists at the moment.
