Great_scot_selfbuild Posted 2 hours ago Posted 2 hours ago I've come across this statement: “Hep2O should not be installed in Continuously operated re-circulating systems (Secondary Hot Water Circulation / Ring main installations).” I was planning on using Hep2O pipework from the plant room to the end points, with the long hot water runs (20-30m) having a 10mm return line to enable circulation to avoid running taps, wasting water and waiting for the water to heat up. I was sure I'd come across this approach by others - is this something I should be worried about? if not, why not?
