marmic Posted 6 hours ago Posted 6 hours ago morning all, We have various types and sizes of insulation left over from our passivhus build (cut-offs and a few full sheets where we had to buy packs). Before trying to flog on ebay or give away thinking about insulating between rafters on one of our stables we use as a daytime room for humans, storage, and dog kennels. We had been racking up the electric bill heating with oil filled radiator whilst dogs were in there and we were in caravan (but in house now 😀) - but for convenience we'll still use as kennels occasionally and still for human use during 'horse time'. So would be nice to keep slightly warmer in there! The questions I'm asking myself is whether 1. will just partially insulating actually make any difference? 2. will I create a damp problem? It's a very un-airtight space. And roof is just osb sarking and bitumen corrugated. walls timber stud with shiplap on outside and osb internally - definitely won't be insulating walls - not practical and will create damp! opinions (usually plenty on here!) would be appreciated please..... hagwe
Redbeard Posted 2 hours ago Posted 2 hours ago 4 hours ago, marmic said: will just partially insulating actually make any difference? When you say 'partially' do you mean 'the roof, not the walls' or 'only some of the roof'? The former I'd say is OK, but if 'un-airtight' means 'breezy as owt' it probably won't gain you a great deal. If you do propose to insulate the roof can you get to the gables to drill ventilation holes in the gable at each end (you'll need a good few between each pair of timbers)? For minimal structural diminution you ought to drill on the centre line (75mm if they are 150 timbers, for example) but that limits the insulation you can get in. It could still allow 50mm though which (crudely) could drop the U value from say 2.0 to say 0.5W/m2K, roughly adjusted for the 'thermal intrusion' of the timbers. If you are pumping in heat it will reduce the heat loss. If you are expecting it to keep you discernibly warmer on a cold day with the only heat input being the c100W of you I doubt you'd feel a huge difference.
