BingoBango Posted 8 hours ago Posted 8 hours ago What's the best way to insulate the recess of a fireplace (when I say best I mean both cost effective and safe!). I'm using quite a lot of heat out of the back of the recess (when they did cavity wall insulation this bit wasn't insulated). I've had the following suggested - is this safe and is there a preference (and if I fix it to the wall then what do I put on top of the heatproof boards - if anything?). 1). Skamotec 225 - Skamo Enclosure Board 2). Vermiculite fire boards 3). Calcium silicate Insulation boards - very expensive 4). Rockwool FirePro / RW5 (non-combustible mineral wool) e.g. could I use the Rockwool FirePro and then cover it with a Vermiculite Fire board and paint over the top? I'm more than happy to reduce the size of the recess - it doesn't need to be as big as it is for us. Thanks
