AidanGee93 Posted November 19, 2025 Posted November 19, 2025 Painters advice: Using a water based paint for my walls, first coat went on lovely but when dry I noticed on most of the walls little air bubbles (some as big as a fifty pence piece). Let it dry and I sanded them down which worked. Upon painting second coat most of them bubbles have reappeared? Id love to know you're thoughts/advice for treating as I'm thinking the walls where never plastered...just plasterboarded and joint taped and Mabey the paints seeping behind the paper on the plasterboard causing bubbles?
