Redbeard Posted September 15, 2025 Posted September 15, 2025 The (external) doors I want to deal with do not have sufficient clearance to allow me to use self-adhesive D/S, so I need something with a 'ground' which either tack or screws on. I prefer the screw-on variety as they tend to have oval holes, allowing you to 'nip them up' with the d/strip touching the door, then you can tap to adjust of the door is at all bent. Many options come with a brush-pile or semi-rigid rubber d/s. I would prefer something with more 'give' than the hard rubber and less tendency to leak than the brush pile - say quite 'squidgy' silicone 'rubber'. Any suggestions? Thanks in anticipation.
