mike361 Posted September 13, 2025 Posted September 13, 2025 CONSERVATORY TO BE CONSTRUCTED AS PER THE FOLLOWING: · Glazed window units to be anchored securely to masonry walls using stainless steel 30mm x 2.5mm anchor straps, MINIMUM length 600mm at not more than 1000mm ctrs and at either side of door openings. · Glazed window Am I over thinking this but does this mean fixing bat straps directly to the underside of the 150 pvc cill then Bend it down on the block work then fix
