G and J Posted July 30, 2025 Author Posted July 30, 2025 Just to close this off.....we decided that we would stick with the one supplier/system which meant not bucking the norm, and going with an inward opening door. (The issue with the chosen system was the mobility threshold machining). We did do a cursory online search and couldn't easily find an alternative anyway, and the comments about wind made us think...thank you The other issue, for anyone treading the same path, was we were trying to make best use of a tight entry way, but in practice an inward opening door (which we can accommodate) uses less overall space than the external requirements for a "turning" space outside the door if outward opening.
