Carol W Posted March 16, 2025 Posted March 16, 2025 Hi, I have a lounge kitchen diner extension. The whole room is part extension, part old house. The extension bit has a pitched, vented, cold roof. The builder failed to tape the joins between the foil backed insulation and those joins just happened to coincide with the plasterboard joins and are pretty close to the joins on the insulation between the joists. After a while I got some water marks in lines on the ceiling right below where the untaped joins are. The builder has cut out the plasterboard around the lines and taped the joins on the lower insulation before replacing the cut out plasterboard and re plastering over it. However, he has only done this for two runs, not the third which is showing very light water marks after a year. He thinks the water marks there are purely from the build drying out. The higher levels are not showing any lines. The lower lines are above the kitchen area. I've seen that there are vapour barrier paints available. Since the ceiling has to be repainted due to the re plastering I'm thinking it would be a sensible extra precaution to use such a paint. Has anyone used one and if so, what brand is best?
