Shower pump - fix or replace?
Hi folks
We have a Stuart Turner Showermate eco 2 bar Twin Pump 46500 - was fitted back in 2018.
All been fine until a week ago when it wouldn't turn itself off after a shower.
Only way I could get it to stop was turning off power at the RCD in the airing cupboard.
Since then - it won't do anything (I've changed the fuse in the RCD just in case).
Is it worth getting someone to try and fix? Or, given the original cost was 145+fitting, better to bite the bullet and order a new one?
thanks!
1 hour ago, RunningAround said:
Hi folks
thanks!
You could try to strip it down and clean the flow switch(es), see if YT has a video on how-to, but these things just don't last forever. Defo sounds like a flow switch issue, so if that turns out to be a serviceable / replaceable part and it's cheap, then you may as well go for a fix (but that's on the proviso that the pump runs quietly and doesn't sound like it is dying elsewhere too).
Don't hold your breath getting a replacement switch from ST. They told me my jet pump was not field repairable so did not stock any spares for it. Eventually found a shaft gland for it on ebay.
