Bath waste run - slight rise or thru floor?
Hopefully the pictures should do most of the explaining here. It's a corner 'freestanding' style bath so no removable panels. Instructions show flexi waste through the floor. However our 1st fix for this room assumed a regular panel bath so the waste pipe for the bath has been installed alongside the bath rather than under the floor. Should I change this whilst I still can or will this (slight rise over lip of bath frame) likely be fine? Although photos show a short flexi adaptor (Flexcon6 I think), will have to use a longer one (Flexcon2?) as there isn't enough 'flex' to get your hands in to tighten the fittings with the bath at a suitable angle with this one. Can't see a way to avoid a flexi in this case either way, I guess same as a regular freestanding bath.
IMG_20241203_104521.thumb.jpg.584472199e4ad359ce5f188afe4cc944.jpgRoom - general view
IMG_20241210_200353.thumb.jpg.c5148cf5d80e4d91d866a893bd70424b.jpgSlight rise as waste exits from under bath
IMG_20241210_195330.thumb.jpg.c14308e9aea95c963b57cc3d0f5e33bd.jpgFlexible fitting
IMG_20241117_172059.thumb.jpg.4a39bca4bb8a23165364930be10e48ce.jpgCeiling below (proposed thru floor to follow orange line
