tommyleestaples Posted November 18, 2024 Share Posted November 18, 2024 We are just about to insulate our roof space which will be used as a useable loft room. The new roof will be tiled with a breathable membrane. The rafters are 100mm deep. I plan to install Celotex PIR insulation or something similar in-between the rafters and then over the rafters to get the required thickness and U Values. I have ready conflicting things regarding the air gap required between the felt and the insulation. I have read it should be 50mm gap but as we are using breathable membrane could we get away with 25mm gap? Link to comment Share on other sites More sharing options...
Redbeard Posted November 18, 2024 Share Posted November 18, 2024 I have seen examples with a 25mm gap and no problems. I have also seen horrendous condensation and mould on breathable membranes with a 25mm gap (and admittedly some other poor practice too). The Gov't Best Practice Guidance for rooms-in-roof says 50 (https://assets.publishing.service.gov.uk/media/61d727d18fa8f50594b59305/retrofit-room-in-roof-insulation-best-practice.pdf) and that seems to me to be a good a**e-covering 'belt and braces' (to mix my metaphors). 1 Link to comment Share on other sites More sharing options...
