16 amp external unit
JustStartingOut
I need a 16 amp external socket and looking at having either a twin 16 amp socket unit or seen a unit with 1 x16 amp and 2 x 13 amp sockets in a single unit protected with RCD’s.
Cable was run during the build from fuse box to external wall and fitted with 32 amp fuse. See attached picture for type of fuse.
so can I simply connect the unit with RCD’s to the cable or will it be a problem as I understand the fuse has built in trip.
