Anyone want spares for a Kidd boiler like this?
Ours is going to be replaced shortly with a heat pump. It has a standard EDGB Inter 2011 burner so if anyone would like any parts for spares, the motor, control box, oil pump, photocell etc are all in good working order having been serviced regularly. Probably usable on many other boilers with the same or similar burner.
Have already put on local FB and Freecycle but so far no takers. It seems a pity to scrap off a load of good working bits.
Edited by sharpener
Hi Sharpener
i have a Kidd boiler. Image attached. It was built 2006 so before yours.  We need some parts. Do you think yours would provide?
Where about are you based in case we could collect? Our boiler is in Exeter.
many thanks
Mark
Ours is a Model 1 commissioned on 26/6/95, although many parts have been replaced over the years so are not that old.
We are in the S Hams so within a reasonable distance from you.
If you can let me know what parts you are interested in we can probably work out if they are compatible.
Last call everyone!
Otherwise it will all go for scrap next week
