8 hours ago, Iceverge said:
Scissors trusses may be a choice if you did want the vaulted look.
400mm is quite generous for the floor build up. You could probably slim it down a bit in various rooms with some top hung posi joists.
18mm flooring,
220mm posi joists
12.5mm plasterboard x 2
3mm Skim
266mm
Or
18mm flooring,
220mm timber joists
17mm resilient bars
12.5mm plasterboard X 2
3mm Skim
285mm
Our span means we could get by with very thick 254mm posi joists but 304mm will actually work out cheaper and will be thinner and lighter to handle too, and gives slightly less deflection so a better feel.
And with flooring on top and plasterboard below that gives us damn near 8’ for each floor and cheap standard roof trusses.  I like cheap and standard.  No alarms and no surprises, please. (To quote a well known lyric!).
