Will A Posted May 28, 2024 Posted May 28, 2024 Hi, Looking for some input regarding the sudden appearance of cracking to the Aircrete blocks to the gables. The house was built in 2016/17, the mortar used to construct the block walls is M4. Cracking to one gable started to appear 5 months ago, and to the second last month. The run of the wall is just over 8.5 meters and no movement joints were installed, the outer leaf is brick. Should I be concerned? Thanks in advance The white X marks where each crack is, the cracks appear to run vertically and the mortar is also cracking.
