Strubo Posted May 27, 2024 Posted May 27, 2024 I plan to convert an attached 6*6M garage into a gym, Iwill use free weights and a max loaded 600kG rack. The garage floor is concrete, I would like to insulate the floor and bring it up the the house floor level, which means I have around 100mm for insulation. What floor make up would the group suggest? I was wondering if a floating floor would be possible, however as room will be used as gym, this might not be possible. In that case was thinking 100*47mm treated timber joists on top of the concrete, at 400 or 600mm centers. I plan to use 20mm rubber mats as the floor. What would you reccomend below the mats, Plywood or T&G circular board and what thickness? Thank you in advance for any help
Andeh Posted May 28, 2024 Posted May 28, 2024 From my layman's opinion....I'd prob opt for 80mm PIR, 20mm tongue & groove chipboard glued & floated on top of PIR.....then I'd prob use doubled up rubber mats to absorb the blow of dropped weights. I imagine that'd make the whole room really bounce if you are not careful!
