Catford Bags Posted April 9, 2024 Posted April 9, 2024 Hi All Just wondering if anyone has attached Renusol rails to Unistrut. Seems completely straight forward with M10 Varisole L brackets but just wanted to double check that i'm not missing something. Cheers in advance CB
Dillsue Posted April 10, 2024 Posted April 10, 2024 Not sure of your set up but if your using unistrut why not fix your panels directly to the unistrut using M8 chanel nuts(zebs) and any panel clamp using an M8 bolt. 1
Catford Bags Posted April 10, 2024 Author Posted April 10, 2024 1 hour ago, Dillsue said: Not sure of your set up but if your using unistrut why not fix your panels directly to the unistrut using M8 chanel nuts(zebs) and any panel clamp using an M8 bolt. I'm building Heath Robinson groundmounts. MCS mate will sign it off.... I think that the panels have to be attached to certified rails. The Renusol rails will be the horizontals. Unistrut the verticals.
Dillsue Posted April 10, 2024 Posted April 10, 2024 I thought it was just the panels that carried the MCS certification?
