What is the best way to install a bifold foor in a solid wall with 200mm of external wall insulation?
I want to minimise thermal bridging (though the bifold door is a massive bridge) and install the door in the insulation, this may mean I get get away with standard size cills. But what's the best way to do this?
Do you think some eps 300 would be strong enough to hold the door if I make a frame up with it? Or should I use timber or steel hidden in the insulation?
