The above is installed in a 300L HeatraeSadia Santon Premier Plus unvented cylinder switching a motorised 2 port valve on the cylinder coil, apparently its differential  switching is only 1.5C, switches off at 60C but on again at 58.5C, I can't find any info in the spec sheets re the differential switching but would have thought it should be somewhere in the 5C to 10C range like most cylinder stats.
Any info on this stat from anyone?
Edited by John Carroll
