Graham1967 Posted October 3, 2023 Posted October 3, 2023 (edited) I am installing a pagoda over a porcelin patio. Two posts will be postcreted in the lawn, and two will be mounted into the patio. I was planning to use fence post bases for the two patio mounted posts (with 4 x bolts going into the tiles/sub base).... drilling into porcelin with diamond drill bits and using chemical resin for fixings. The issue I have is that the patio has a fall. How do I get the posts plumb? I read a few articles that recommend using galvanised steel washers under the two bolts on one side to level out. Would this be the recommend method to get the base/posts vertical? Post base screenshot attached Edited October 3, 2023 by Graham1967
