cheekmonkey Posted October 3, 2023 Posted October 3, 2023 We're 5% on supply & fit as we're change of use from Agri to Resi. I'll be using the same contractor to fit: - Solar - Heat pump - Underfloor heating (from heat pump) - General Plumbing (1st & 2nd Fix) Am i right that 'renewables' are 0% VAT regardless but which bits fall into that? Do we need to break up the heat pump & underfloor from the 1st fix hot water etc? Does MVHR also fall into 0% VAT? (different contractor) Thanks in advance
