johnhenstock83 Posted May 9, 2023 Share Posted May 9, 2023 good morning, our extension is more or less ready, the skimming is drying nicely. I suspect we'll be able to start decorating (painting, flooring, second fix etc.) this weekend. I found 12mm thick laminate for a good price, we're probably going with that. I wanted to ask if people have some advice around underlay/insulation. about two thirds of the extension is new, hence 150mm celotex on a suspended floor, 80mm screed. the old bit is solid floor, directly on the ground, no insulation. I thought about laying aluminium foil all over the place, tape it with alu tape, foam underlay on top and then the laminate. is it worth spending a bit more or is it overkill? thanks Link to comment Share on other sites More sharing options...
