BarumMike Posted March 25, 2023 Posted March 25, 2023 The photo shows our front steps which are probably Victorian. The risers of the bottom three steps but not the top one have blown outwards cracking and loosening the tiles. A number of questions. Am I right in assuming this is due to water penetration causing expansion of the substrate below each step? How far back should I go excavating below each step before rebuilding the riser and laying the replacement tiles? I will probably leave the top step/riser undisturbed and just replace the two broken long yellow tiles. Should I assume I will not be able to recover any tiles intact from the bottom three risers when ordering replacements? Any further tips?
