Outdoor Toilet Blocks
Hi folks, I'm building a toilet block about 2x3 metres. We wanted to save the pennies on this one and went with standard 63mmx38mm CLS for the framing.
However, I'm now wondering if this was silly, and I should have picked up some 3x2 C16 instead?
It'll be supporting one large UPVC window on one side, and another smaller one on the opposite side, also looks like I'll have to double up the CLS on these walls to accommodate them.
I've also doubled up on the roof rafters for more strength. Roof will have 40mm PIR and felted.
So I'm now actually considering pulling the whole thing down and redoing it with the larger C16?
But could I just get away with the smaller CLS and just double up on lengths here and there, like I've been doing...?
Thanks for your thoughts
That is a bit skinny.
What centres are they on?
Is the cls spanning the 2m?
If you hang off one, does it deflect a lot?
You say a toilet block. Is this for private occasional use, or public?
They're 40mm centres, with a couple of odd centres to make up for the bespoke length/depth of the unit.
I've doubled up on the CLS at potential stress points or where they need to span longer than a metre, like the roof overhang.
I'll also double up around windows and door.
This is for regular guest use.
It sounds undersigned for a 'proper' building, esp now you mention overhangs.
It feels too flimsy to you so I suspect it is.
A sketch or photo?
Yeah, it's coming down!
Just ordered the C16....
what a numpty, eh! :D
It's not too far along though, and I'll always need that CLS for something anyway
Rather do it right than chance it!
cheers
