How do 10 kw inverters work with Octopus 9kw limit.
To quote Octopus says "A solar system with a maximum generation of 9 kWp",  hence what use is a 10kw inverter?
I am right to assume Octopus does not care about the number of panels provided the inverter is not over 9kwh?
If the battery is separate from the PV inverter is the battery export capacity disregarded in the Octopus 9kw limit?
