Hi all,
We treated ourselves to a shinny black induction hob, which looks and operates great...
On the flip side we have a vent on the external wall, which is currently sitting with no vent cover (only moved in and the last trades are finishing up) and as you could imagine, it's a source of heat loss, as the wind is blowing through and out through the small gaps in the extractor in the middle of the hob 😕
We were hoping to get recommendations on a 220mm x 90mm external vent cover, one that would slot close when the extractor is not in operation and when it's in operation close back up or something along those lines to help stop the wind coming in and causing us a cold spot in that area.
Hoping to see if there is something better than one picked up for a few quid at the local hardware store.
Many thanks,
Joe
