bildbildbild Posted November 21, 2022 Posted November 21, 2022 (edited) Hi All, I wonder if anyone on here could advise or came across the following: -An overseas 2 story house built using structural concrete frame and external non-loadbearing masonry cavity walls -I would like to add an external insulation (200mm thick EPS) and corrugated galvanized metal cladding. The question is, how one would fix the metal sheets to the existing building? I was thinking about adding timber frame (to reduce cost) rather than steel frame! Any advice? Thank you Edited November 21, 2022 by bildbildbild
