Rooftop Posted August 2, 2022 Share Posted August 2, 2022 Hi Have a 6 x 7m loft space currently with 4” x 2” ceiling joists Looking to have access for storage and a model railing way setup and maybe a desk to use from time to time Which option is best 1) add new joists in parallel with existing from wall plate to wall plate with load bearing walls in middle (2.4m joists joined with M12 + joist connectors) 18mm OSB board for flooring which size C16 could I get away with? 2) add another 2-4” on the existing ceiling joists (at 90 deg angle on existing) with 18mm osb flooring Thanks in advance Link to comment Share on other sites More sharing options...
