Harvey HV3 - rising water in brine tank issue
Bobbyboo
Just reinstalled my Harvey HV3 non-electric twin softener in my house and seem to have an issue where the water in the brine tank keeps rising. The unit is barely 4 years old. The fault developed after it sat empty in a box for 4 months while my house was being built.
The water first rises quickly to the height of the salt, and then slowly keeps rising further as I run the water. After about 2 days of normal usage, it actually rises all the way to the overflow. This is before the automatic regen kicks in, but a manually triggered regen causes the water to drop again, about to the level of where the salt sits.
I have taken out the brine valve, and all seems ok (riser sits fine within the well, and nothing is jammed). Any suggestions where else to look?
Edited by Bobbyboo
