Gelec Posted July 3, 2021 Share Posted July 3, 2021 Hi I’m looking to use an infill drain cover to hide the drain in the patio. The current drain cover is on a 45 degree angle to the house and the drain shaft is on an angle. Because the drain shaft is a rectangle brick shaft (instead of circular) I can’t just adjust the angle of the new drain cover. Setting the infill drain cover on an angle creates a lot of extra cutting of slabs. Any suggestions or tips anyone?? Link to comment Share on other sites More sharing options...
