Wooden frame for single oven
goppo
Hi all,
We have recently replaced a double oven with a single oven, but the new oven is not as wide as the old and couldn't be mounted to the cupboard. Here's a photo:
I'm thinking of building a wooden frame for it and having a shelf above it. The gap on each side of the oven is around 60mm. Could something like this do?
where the oven sits between the the two 'stands' underneath a piece of plywood. If so, what timber size should I use for the frame?
Any advice appreciated. Thanks.
Edited by goppo
