Hey all,
I'm looking for advice on best practice to remove and cap an old vent stack. We want to cut it off low to the ground, if possible flush with the ground. Seal the top and then cover over.
The pipe itself is 110mm 'low risk asbestos', so I'm aware I need to be careful in how I handle it and cut it down. But can I just use a drain blanking cap in the top? Doesn't seem substantial enough.
Many thanks,
Matt
