Thanks Phil that's super reassuring.
Another question, and again apologies if this is basic.
The flow temperature of the 14kW heat pump is set to 35 degrees. The space heating pump on the internal DHW cylinder is set to Speed 2, which is required to generate sufficient flow for the UFH zones. There is a 5-6 degree drop-off in flow temperature once the heated water flows through the space heating pump into the UFH manifold (flow temperature drops by 5-6 degrees, not return temperature), and I can't figure out why.
When I set it to Speed 1, this drop-off in flow temperature goes away.
Do you know what could be causing that?
